Window tint removal
Bootyologist (__i__)
Whats the cleanest method of removing tint from window? Im thinking a ravor blade and some soapy water??
i just had to do remove the tint from my front windshield. A tip I learned is to take the razor blade and cut a small piece of the tint off at the upper top of the window at farthest point at either side. Then try and peel the tint down the side and curve it at the bottom so you get the bottom tint which is a bish to remove. The strip you remove should look like and L shape. Then keep repeating across the window. Makes it a heckuva lot easier to cleanup. I found windex turned the glue into a gummy stringy stuff that was easily wiped off with a cloth towel
juiceweazel
22
07-23-2002 11:29 PM
