Garage door torsion spring question...
Old Feb 28, 2004 | 10:58 PM
Zuerst's Avatar
Zuerst
Default Garage door torsion spring question...
My garage door originally only has one torsion spring but it snapped recently. Is there any advantage to installing 2 torsion springs?
Old Feb 28, 2004 | 11:06 PM
Snoopy's Avatar
Snoopy
been there done that
it'll close faster :eek3:
Hondaman's Avatar
Hondaman
Black Pearl
Depends on what kind of door you have. (ie size and material) Are you using an opener? The other spring will help you with the dead lift portion of opening, but not much else.
Old Feb 28, 2004 | 11:23 PM
Zuerst's Avatar
Zuerst
Not even extend the usable life of the spring just a "little" bit??? Or maybe help extend the life of garage opener motor by making the door a "bit" more lighter to pull?
Old Feb 28, 2004 | 11:26 PM
Hondaman's Avatar
Hondaman
Black Pearl
It probably will. You would put less tension on two springs than you would on one. The two springs would work together to help lift the door.
Old Feb 29, 2004 | 06:13 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
I think if it's designed for 1 spring, that's all it needs. Once properly tensioned, it's all the help it needs. The motor in mine failed once and I could use one hand to raise/lower the door.
Be careful if you try to fix it yourself. That spring is under a lot of tension and really hurt you if it gets loose when tightening. Our spring broke a month or so ago (first time in about 15 years) and the guy actually clamped it with a wire clamp. It held for a couple of weeks while the new spring came in.
brtecson
Feb 23, 2004 05:12 PM
grampafunk
92+ Civic/EL & Del Sol
2
Aug 24, 2003 11:08 PM
kittykilla
Aug 13, 2003 02:26 AM
bacid
Accord
2
Aug 10, 2003 08:45 PM
madeiniraq
Jun 24, 2002 06:46 AM
