Damn Integra oil filter
Originally Posted by rich
that's one thing i dont miss about my integra
h:
You think the Integra is bad?
Check out a Volkswagen.
1) Remove Mud-Guard
2) Drain oil out of oil pan.
2) Remove Oil-Filter-Casing Drain Plug w/ a allen wrench.
3) Drain oil out of filter-casing.
4) Use 36mm socket to remove oil filter casing.
5) Replace Oil Filter and O-Ring.
6) Replace Oil Filter Casing Drain Plug
7) Replace Oil Filter Casing O-Ring.
And, the Oil Filter is way up in the worst spot imaginable. and it takes 6.5qts of oil!
1) Remove Mud-Guard
1) Remove Mud-Guard
1) Remove Mud-Guard
h: You win.. :chuckles:
Originally Posted by NorCal DC4
h: You win.. :chuckles:The filter location on the Element is terrible. You have to reach up through the wheel well to get a good grip on it.
That brings to mind a good question... where is the filter located on the VQ35DE, anyway?
h:
h:
When I change oil on my Dad's B20 CRV it is a pain in the ass mostly because there is no real room to swing a rachet up there. I never have problems getting it off as much as I do turning it 10,000 times to get it off.
Honda oil filter locations suck compared to Toyota, or most of them.
Well, I'm not surprised that the K-series block design carries on the traditions founded by it's B-series predecessor. I'm kicking around the idea of buying an oil cooler / oil filter relocater when I get around to boosting...:thinking: Hmm.
1) Remove Mud-Guard
1) Remove Mud-Guard
maybe the jetta that i worked on is older than your vw, but that oil filter was a few inches below the valve cover. it was easy as cake to get if off:dunno:
Tr0LL
Apr 10, 2004 05:12 PM
