Help!!! My spacers are stuck to the roters
Old 12-04-2003, 04:39 PM
BonzoAPD
BonzoAPD's Avatar
Default Help!!! My spacers are stuck to the roters
I am taking off my summer tires for the 1st time and the spacers that came with them are now attached to my roters and won't come off. What can I do to get them to come off?
Old 12-04-2003, 04:43 PM
airon
AARONNOJIMA.COM
airon's Avatar
why do you have spacers on there for? offest not right?
i would just say heat them up and get a screw driver and hammer and start puonding....i guess
Old 12-04-2003, 04:44 PM
accordhybrid
accordhybrid's Avatar
WD40 and a small screwdriver is your friend
Accordhybrid
Old 12-04-2003, 04:47 PM
AP2
Moderator Alumni
AP2's Avatar
Get some WD40 and a rubber mallet.......unleash hell.
Old 12-04-2003, 04:53 PM
DB7 2.0
Banned
DB7 2.0's Avatar
use your teeth :exnbp:
Old 12-04-2003, 05:15 PM
DakarM
DakarM's Avatar
that's what I told him
heat it up with a hair dryer or a heat gun and hit it with a rubber mallet.
'00 Dakar Bus CRS Edition
LCD Squad #0001
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
First, drown them in Liquid Wench...er.. WRENCH. :chuckles:
Then, as DC2 alluded to, whack the spacer using either:
a) a wooden mallet and a section of 2x4, to protect the spacer
or
b) a fairly soft rubber mallet.
In either case, wind up and swing like hell. Good form and follow-through are key.
Repeat as necessary, though if done right, they should pop loose with one or two blows.
Godspeed.
Old 12-04-2003, 05:35 PM
BonzoAPD
BonzoAPD's Avatar
One came off, one will not. I have been at it for a 1/2 hr now. If I can't get it off soon I will have to put the summer rims back on and bring it to someplace to change them hnoes:
Old 12-04-2003, 05:52 PM
BonzoAPD
BonzoAPD's Avatar
OK, now my two front ones are off and my snows are off. The back ones are stuck too and these look like they will be harder since there is more to the roter in the back. Anyone have any advice on the back ones?
Old 12-04-2003, 06:57 PM
BonzoAPD
BonzoAPD's Avatar
any teg people out there :happysad:
