*****Synthetic oil warning*****
Old Nov 20, 2003 | 11:10 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default *****Synthetic oil warning*****
found this on the R1 forum I go to so I thought I would share.
Originally posted by Jalle
Beware of synthetic oil, it can do terrible things
to you and your beloved motorcycle. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system.
It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action. Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the
ground! But that's not all...
Synthetic oil will round off your gears and spin
your bearings. It will Also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again.
Synthetic oil coats Your sight window and your timing window with a whitish pro-emulsification additive that is both non-removable and highly corrosive.
Synthetic oil will completely leak onto the ground overnight and your dog will drink it and die.
Synthetic oil will wear out your tires and make
your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut. It will contaminate your gasoline causing your bike to stall on railroad tracks and
accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate four timing belts causing them to jump
teeth and break your valves to bits. Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every six miles. Then it
melts the black soles of your riding boots night before you walk across your new
carpeting.
While riding past groups of attractive women it
will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your
swingarm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 55,555.
It also dries out your wetclutch and wets your dryclutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the
year while putting an angry wasp in your helmet for good measure.
Synthetic oil hides your 13mm socket and puts superglue on your earplugs.
Synthetic oil will scratch your faceshield and make your gloves shrink two sizes night before trackday. Synthetic oil stole your neutral and sold it to the Chinese for $1.25. Synthetic oil will make you grow a tail.
:lmfao:
Old Nov 20, 2003 | 11:13 PM
b00gers's Avatar
b00gers
that was pretty funny :rofl:
my mom buys the neutral and sells them on the blackmarket. h:
Old Nov 20, 2003 | 11:15 PM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
404. funnAy not found. h:
Old Nov 20, 2003 | 11:18 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
:rofl: at first I thought it was serious. Maybe the neutral part is true because sometime its hard for me to find
Old Nov 21, 2003 | 03:00 AM
g2tegls's Avatar
g2tegls
MR, ftw
angry wasp :chuckles:
Old Nov 21, 2003 | 04:12 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
I don't use that shit anyway cuz it really will leak out of your engine cuz it can go places dinosaur oil can't.
Old Nov 21, 2003 | 08:15 AM
DriftKing's Avatar
DriftKing
Its half true. Synthetic oil is not good for bikes. mostly because of the clutch slipping. I happily use it in my Accord though.
Old Nov 21, 2003 | 10:25 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:lmfao: BWAHAHAHAHahahahahahahaaaahahahaa
ahahahahaaaa....:thumbup:
Saved. :lmao:
Old Nov 21, 2003 | 10:31 AM
brtecson's Avatar
brtecson
pukimonster
funny:chuckles:
Old Nov 21, 2003 | 10:51 AM
reech-around's Avatar
reech-around
RIP Woong.
i agree...i never used syn on my bike, mainly because it acts at tranny fluid also.
