Need help setting up my FTP server + router
Old Nov 4, 2003 | 03:48 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
Default Need help setting up my FTP server + router
I'm using a Belkin 4-Port Cable/DSL Gateway Router w/built in firewall
So anyway, I've setup the virtual server on the router, feeding all port 21 (FTP) requests to my internal IP
I've tried using my external ip
and I've tried my WAN IP, and my internal IP... obviously I can access my FTP using my internal IP from inside the network, but I want to be able to setup a working FTP.
everytime I try to connect, I get a connection refused error.
I've disabled my software firewall, the WinXP firewall is never enabled ( I double check to make sure it was disabled) and I've tried disabling the hardware firewall... nothing works.
wtf do I do?
PS: Using bulletproof FTP server
File Type: jpg
Old Nov 4, 2003 | 04:02 PM
qtiger's Avatar
qtiger
Set server as DMZ
Old Nov 4, 2003 | 04:06 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
tried that, still doesn't work..... ?
Old Nov 4, 2003 | 04:09 PM
qtiger's Avatar
qtiger
Then your router blows.
DMZ = demilitarized zone = every incoming packet does to the DMZ computer
Old Nov 4, 2003 | 04:18 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
also try forwarding port 22, and set it to passive mode on the ftp.
Old Nov 4, 2003 | 06:21 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
tried that too
Old Nov 4, 2003 | 06:27 PM
sxecrow's Avatar
sxecrow
Banned
Originally posted by qtiger
Set server as DMZ
holy lack of security batman ... not a good idea.
Old Nov 4, 2003 | 07:40 PM
qtiger's Avatar
qtiger
He's troubleshooting, not setting up a permanent solution. :jerkit:
Manin: Set your FTP port to 2121. I bet 21 is blocked by your service provider.
Old Nov 4, 2003 | 08:11 PM
mike01civic's Avatar
mike01civic
Be careful, usually ISP's watch port 21. I read my 'Acceptable Polices' agreement from Adelphia and it explicitly states you aren't allowed to run servers. Just thought I'd let you know.
