CPU temps down...
Old Oct 30, 2003 | 12:53 PM
TeggerLS's Avatar
TeggerLS
Default CPU temps down...
well my CPU temps where in the mid 60's a while back, I installed a thermalright 900a and 80mm fan and they dropped only 5* to high 50's low 60's. I just took the panel off the pc and it's now running at 52*C....:thinking: Guess I need more circulation in the case. I have 3 80mm fans in the case, but I guess they're not doing their job.
MB is 32*C
Old Oct 30, 2003 | 12:54 PM
Brad's Avatar
Brad
wooo nascar!
mine stays below 40 all the time. usually 38 or 39.
i have a lian li pc-65 aluminum case with 4 80mm case fans.
Old Oct 30, 2003 | 12:56 PM
TeggerLS's Avatar
TeggerLS
I wonder if the MB sensor's are shot:dunno:
Old Oct 30, 2003 | 12:58 PM
DakarM's Avatar
DakarM
do you have another thermal sensor?
I have these little small thermal sensors connected to a LCD that gives read out of temp in real time.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Brad's Avatar
Brad
wooo nascar!
hmm, could be.. how old is your MB? also what processor are you running? i have a p4 2.53 and a stock cooling fan on it.
Old Oct 30, 2003 | 12:59 PM
TeggerLS's Avatar
TeggerLS
nopeh:
Maybe I'll get one to see if it's accurate
Old Oct 30, 2003 | 01:00 PM
DakarM's Avatar
DakarM
Originally posted by TeggerLS
nopeh:
I got them free from some show thingy.
They were close to the MB temp sensors. only off by a few degrees in F.
LCD Squad #0001
TeggerLS's Avatar
TeggerLS
Running an AMD AthlonXP 1800+ w/ an ASUS A7m266 MB in the all-to-famous silver geekbert case.
Built it about 2 yrs ago, bout time to build my 3ghz P4 beast:rick:
Brad's Avatar
Brad
wooo nascar!
yeh, arent those battery operated? i thought about getting one but i didnt wanna have to keep replacing batteries. if you wanna put out more money you can get a system monitor thingy that takes up a 5.25" bay.. some have a LOT of functions. my intel monitoring software works just fine for me.
Old Oct 30, 2003 | 01:04 PM
Brad's Avatar
Brad
wooo nascar!
wow i used to have that MB.. bought it like.. 2 or 3 years ago..
heres what dakar is talking about...
edit: after reading the description, this one in particular is made for lian li cases, and also is powered by the regular power supply
$23
and heres what i was talking about...
$40
both from www.xoxide.com
