Stupid Tapping Noise
Old Oct 19, 2003 | 10:04 PM
AcuraFanatic's Avatar
AcuraFanatic
Default Stupid Tapping Noise
I have this weird "ticking noise" that is associated with speed. It's not engine RPM related. The faster I go, the faster it taps. It sounds like it's coming from inside the gauge cluster. Any idea as to what it might be?
Yes I asked Engine Tech. I am impatient.
And no I don't honestly expect straight answers out of 95% of you. :jerkit:
Old Oct 19, 2003 | 10:08 PM
b00gers's Avatar
b00gers
its the africian ticking bettle.
i only said that because of your last line.
Old Oct 19, 2003 | 10:09 PM
b00gers's Avatar
b00gers
seriously...can you stop the noise by holding down the gauge cluster or something? can you hear it at idle? is your turn signal on?
Old Oct 19, 2003 | 10:10 PM
hollaboyz's Avatar
hollaboyz
Banned
that happened in my prelude. except the ticking was coming from the engine. i traded it in to the toyota dealership. never did find the problem
AcuraFanatic
I've held down the gauge cluster, but it still happens. Sounds like something inside the dash. I can't hear it at idle when stopped, but if I put the clutch in when moving it still taps. And no the signal is not on. :fawk:
Old Oct 19, 2003 | 10:11 PM
AcuraFanatic
I'm 99.9% sure it's not engine related.
Old Oct 19, 2003 | 10:12 PM
hollaboyz's Avatar
hollaboyz
Banned
Originally posted by WiLL is your turn signal on?
:lmfao:
Old Oct 19, 2003 | 10:15 PM
LT's Avatar
LT
The deer had to die!
there are a lot of things that could be associated with speed relative ticking sounds:
-CV joints are going
-transmission
-axles
-rock in your tire? (hey, i've diagnosed that problem before for my sister :doh: )
can you narrow it down?
Old Oct 19, 2003 | 10:16 PM
S2Kev's Avatar
S2Kev
Why are you so sure it's not engine related?
Old Oct 19, 2003 | 10:17 PM
AcuraFanatic
-transmission
-axles
The CV joints were recently replaced, along with the axles, so I doubt it's either of them.
I'll try to roll in neutral and see if it still makes that sound but it just doesn't seem like a transmission thing.
No idea about the rock, but I just recently had the tires off, so it'd be recent.
