radiator replacment
radiator replacment
I got a new rad and im not getting ripped off by a garage. Was wondering if any of you could tell m how to flush out the old coolant and put on the new rad any help would be useful thankyou
wooooo woooooooooo
on the bottom of the radiator, there is a plug. looks like a wing nut almost. Loosen that to drain the fluid. Then, disconnect the hoses, and electrical connections (I think 2), and you're left with just the top bracket to take off. Piece of cake.
のんびり~(´ε`)
For an at-home flush, buy some cooling system flushing solution at the auto parts store and follow the directions on the bottle. Usually you'll want to drain the coolant, pour the flush in, fill the the radiator with water, and run the car for 5-10mins(or until it's hot, while parked, of course) with the heater blasting full-hot. Then you drain, fill with water, and run the car again, then drain, and refill with fresh coolant/distilled water mixture. If you want some extra cooling capacity, run a bottle of Redline Water Wetter. It's about $3-4 a bottle and increases the coolant solution's ability to dissipate heat. One bottle will treat your entire cooling system. Water Wetter also lubricates the seals in your cooling system and helps prevent corrosion.
Still here... sorta...
Originally posted by speedshow
its a 93 widebodyek
im replacing the rad so would the cleaner be necessary
thank you
how much would a new rad cost
its a 93 widebodyek
thank you
I can get Fluidyne your car so if you're interested PM me.
のんびり~(´ε`)
its a 93 widebodyek
thank you
its a 93 widebodyek
thank you
I have a 2 core Modine. It was cheaper the fuidyne(that sh*t is $$$ up here).Still you are looking at a couple hundred dollers.
のんびり~(´ε`)
Originally posted by smudge
Water wetter is not an anti-freeze!It is great in the summer but if you are in a cold area(Canada) use anti-freeze.
