New Clutch or Clutch Adjustment
Old 08-24-2004, 10:33 AM
ramartin777
ramartin777's Avatar
Default New Clutch or Clutch Adjustment
Symptoms:
clutch appears to slips for 2-3 seconds when accelerating on flat surfaces and slips even greater 4-5 seconds on hilly surfaces.
5-speed 1998 Accord LX @121K miles
Question:
Does my car need clutch adjustment or new clutch?
Thanks
Old 08-24-2004, 11:14 AM
flyromeo3
flyromeo3's Avatar
sounds like a new clutch to me.
You adjust the clutch if you feel that the clutch pedal needs to be released a bit further before it actually gets the grip.
Old 08-24-2004, 11:31 AM
wedley2
bboy Wesley West
wedley2's Avatar
not sure if you can adjust the pedal if its a hydraylic clutch. my car needs one as well, when i shift gears, the rpms kinda go up 200, it engages not all the way out but its close. so stage one, resurfaced flywheel and lsd next, w00t.
Old 08-24-2004, 01:43 PM
pringle
pringle's Avatar
I've got an '02 and have seen something in my Helms to adjust the clutch pedal. What would this do if adjusting a hydraulic clutch is "useless"?
Old 08-24-2004, 02:30 PM
vtecaccord01
Performance isn't $$$
vtecaccord01's Avatar
it just adjusts the pedal travel not the actual clutch. I just changed my clutch yesterday so i have seem more bolts then i wanted too. I see why it cost so damn much to replace it. The actauly taking the clutch off and replace is like 10 mins. Find all the bolts to get it off is the true bitch of it all. Oh if you do change it, replace your rear main seal. mine was kinda of rotting and glad I replaced it.
