B&M SuperCooler installed *pics*
Cone Basher
After 5 hours it's all done!!!
Mounting the cooler was much harder than I thought it would be, because the zip-ties/rods that it came with were too thick to pass thru the A/C condenser, so we mounted it in front of the A/C condenser using brackets and bolts. There is a 1/2" space between the cooler, and the A/C condenser We had to cut and bend some of the brackets too.
Routing the hose was a bit hard, as me and my dad had to take off the lower center splash guard so we could reach the bottom of the stock return line at the bottom of the radiator. The stock return line had these hose clamps that were a PITA to take off too We also used foam pipe insulation to protect the lines from heat and sharp edges.
It looks a little crooked and messy, but I'll go ahead and redo some of the zip ties and foam insulation to make it look neater (even though the bumper covers it all up ) sometime later on. When I started the car there were absolutely no leaks or any other kinds of problems, but we did have to add about a 1/2 quart of fluid since we spilled some, along with the added capacity from the added cooler...
Now I need to see how this helps out the transmission at tomorrow's Auto-X
Cone Basher
The transmission still warmed up just as quickly during the cold weather thanks to the SuperCooler's "bypass" feature:
http://www.bmracing.com/products/acc...perCooler.html
It costs more than most other coolers, but to me it's worth every penny of it IMO, especially when the transmission costs thousands, while this cooler only really cost me about $75 including a quart of Honda ATF-Z1, and a 10ft length of 3/8" transmission hose (cooler came with 4ft already).
Im So JDM
Thats pretty cool man. Can I ask something, How does that benifit for your car as far as performance wise? Like I get that it keeps the tranny cooler but does that really affect you? JW.
Jon
Jon
Guest
Posts: n/a
Allows you to run more power through the auto tranny more reliably is about the bottom line. Heat is about the biggest problem with an auto tranny holding power and abuse.... Pretty much the best update for an auto tranny you can do, next to an upgraded/custom torque convertor.
- Nathan
- Nathan
- Nathan
- Nathan
THE RED 6th GEN Coupe
An Auto Tranny cooler is also VERY good to have if you spend alot of time in traffic with the A/C.
Hot summer heat kills trannies. I had an old dodge FWD (I know-I know) it ate trannies in the summer with the A/C on until I installed a tranny cooler.
An ATF-cooler is worth every penny compared to new/rebuilt tranny.
cb7 fanatic
Can you buy a tranny cooler for just general purpose use, or do you have to buy them vehicle specific? Would adding a tranny cooler prolong the life of the transmission? The reason I ask this is because my mom is about to buy an auto Element, and she is worried about the tranny in them(because tranny's don't come cheap) so I was wondering if we added a tranny cooler, if that could possibly offer a little peace of mind.
Cone Basher
Jon
Jon
- Nathan
- Nathan
Originally posted by MeiSoSlow
Is the tranny cooler worth it when the ambient temp is around 110? Summers in Vegas make my tranny slip like crazy
Originally posted by KjG8erZ8
How much $ do these coolers run?
The reason why I chose the supercooler was because it can't overcool the fluid on startup in cold weather (the stock cooler is warming the fluid at this point), since it kinda "bypasses" the cooler core...
transmission->stock cooler/warmer->SuperCooler->back to transmission
All the mods and you still left the intake resinator on the car? Let her breath man!!
