Having Problems fitting 19's with such a low drop.
I'm not going to dog you. Obviously the car is show for the most part. But those wheels are just to big to ride on w/a drop like yours. If I were you, I would consider investing in an airbag suspension, ride high or stock height when your rolling and then dump it when it is parked. Otherwise you pretty much have an epidemic.
There's actually a company that makes a "bent" trailing arm for the lower control arms in the front. They're clearanced to allow 18's and 19's on lowered cars to turn without rubbing. No cutting needed. Though I can't think of the company off hand.
Stick a fork in it... because this thread is done.
:closed:
:closed:
