Is There A Way To Remove Chrome??
Old Feb 13, 2006 | 09:14 AM
SOCALDC4's Avatar
SOCALDC4
Default Is There A Way To Remove Chrome??
I Am Gonna Get A Lude With Some Chrome Rims On Them....i Want To Know If It Would Be Hard To Remove The Chrome And Get Them Powder Coated..........also What Might The Price Be If I Get It Done?????
Old Feb 13, 2006 | 12:33 PM
Civic2Scooby's Avatar
Civic2Scooby
sandblast...powdercoat.
Old Feb 13, 2006 | 12:48 PM
SOCALDC4's Avatar
SOCALDC4
Will They Look Real Good.......or Kinda Crapy
Old Feb 14, 2006 | 09:52 AM
Robstunner's Avatar
Robstunner
y0! Vito!
sandblast :thumbsup:
Old Feb 18, 2006 | 11:16 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The quality work depends entirely on the surface prep and post-blast cleaning. An experienced powdercoating shop will likely be able to do all the necessary work under one roof.
Google "powdercoating near _______," entering your ZIP code in the blank space. It's the fastest way to search for business listings in your area.
Old Feb 18, 2006 | 11:22 AM
TheOtherDave™
Apathy Kills
As far as the end result is concerned, I wouldn't worry that much.
Assuming the sandblasting is thoroughly and carefully done, the finished product will look fine. The process involves spraying a charged enamel powder onto the bare metal, then baking the powdercoated rims in an oversized oven.
Under high heat, the powdered enamel then melts and forms a very tough finish over the entire surface of the rim. You'll be able to pick your color as well as the level of gloss, so choose carefully... if you change your mind after the process is complete, you have to re-strip the rim and start all over.
