body work
Old Jan 20, 2006 | 12:12 PM
ajth87's Avatar
ajth87
Default body work
i got a 91 accord that has some rust going around the drivers side back wheel trim and then it goes through the back bumper, I have to keep my bumber up by screwing it on. and then there is some on the passenger side wheel trim. What is the best method that is not to expensive, to remove the rust?
Old Jan 20, 2006 | 12:58 PM
AcuraFanatic's Avatar
AcuraFanatic
Unfortunately there's no easy way to fix it without spending money to do it right. I'm currently restoring/building a '95 Civic EX Coupe with 217K on it. When I picked it up, it had two rot holes the size of footballs in the quarter panels.
I ended up having to cut off the entire 1/4 panel, then cutting out the rusted section, welding in new replacement metal, acid dipped the entire panel, undercoated it, welded it back on, little bit of bondo, then primered and sanded the shit out of it, then paint.
You can put bondo there but it'll come back. Whether or not you feel like spending the money to fix it depends on how long you plan to have the car. Luckily I have hookups, but the work done just on the two 1/4 panels I had done would have costed $2500, without paint. :eek4:
Old Jan 31, 2006 | 04:01 PM
kiddcarbuff's Avatar
kiddcarbuff
goo look at a few psots ive made about fixing that rust, its a bitch if you cant work with metal
