OEM rear trunk emblems
Old Jun 7, 2005 | 10:58 PM
mdaman's Avatar
mdaman
well im getting my dents taken out of the trunk lid and getting it repainted. Anyone have an estimate of how much it would cost to get them shaved at the same time?
Old Jun 8, 2005 | 03:35 AM
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
if you do it yourself, shouldnt cost you more than $30-$60
to give an estimate would be hard, because it all depends on how big the dents are, how much bondo work has to be done, and how long the repainting procedure is going to take.
Old Jun 8, 2005 | 03:49 AM
carta79's Avatar
carta79
Life after death
Originally Posted by teg92
say that again, Bondo will not fall out, I have done this twice before and it never cracked or anything
I'm not a fan of Bondo, I've seen the headaches Carlos went through on his Accord. Yes it cracked quite a bit on his car.
-Ok but you have to seal the backside of the holes; you can't just plaster bondo in there. You can see where the "A" emblem clips into on the backside of the trunk but not the "ACURA" emblem. That's why I made this post; I don't see a way to seal off the backside of the "Acura" emblem holes. All I'm trying to do here is to find the best possible way of doing this.
Originally Posted by minh
the ACURA badge have holes behind it ? i thought its just glue ?
That's exactly what I thought, but yes the Acura badges on the trunk have holes behind them. I'm thinking about having the holes welded shut, grinding them down, sanding and repainting the trunk.
Different body shops have different labor charges. It would be difficult to give a good estimate.
Old Jun 8, 2005 | 12:16 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
If you want a truly permament solution, the best way is to strip the trunklid, weld up the holes & grind the surface flush. then re-prime and re-paint the entire lid.
It's a hell of a lot of work. h:
Moved to App/Cos.
Old Jun 8, 2005 | 12:55 PM
carta79's Avatar
carta79
Life after death
^Ok cool, so I'm kind of on the right track. Thanks for the reply. :thumbup:
Old Jun 8, 2005 | 08:58 PM
minh's Avatar
minh
so thats why the acura badge didnt nudge when i tried to take it off using a blow dryer h: it worked on my 94 legend though
