Integra side moldings and sideskirts...
Old Nov 14, 2004 | 09:11 PM
95Ateg's Avatar
95Ateg
Default Integra side moldings and sideskirts...
I was thinking about taking the door moldings off and the plastic sideskirts off my 95 2 door integra. I am doing a complete respray and wanted to know if there are holes underneath either of these pieces? Are the just glued on or bolted on? What is underneath them?
Anyone have any pics with them removed?
Thanks
Matt
Old Nov 29, 2004 | 04:08 PM
1jz gte_ jza70's Avatar
1jz gte_ jza70
rhd the only way to be!!!
youll have to put the side skirts back on believe me, and as for you side molding it may or may not have holes depends on if its the tape type or clip but integras look weird with out side moldings believe me i took mine off and they went right back on
Old Nov 29, 2004 | 04:13 PM
teg92's Avatar
teg92
WHAT OK YEAH!
if you take the side moldings out there are going to be holes, My friend has a 95 teg and he took the moldings out and there are about 7 or 8 holes on each side. The side skirts has 2 screws and the rest are clips
Old Nov 29, 2004 | 08:14 PM
Nelson's Avatar
Nelson
Administrator
What I would do is:
Remove moldings and side skirts, paint under them, then paint the moldings and sideskirts themselves.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Nov 30, 2004 | 12:47 PM
b18coupe's Avatar
b18coupe
type r's dont have side moldings, do you think they look weird? keep the side shirts on, or just get the optional ones that go up in the back, and shave the molding. its not that hard about 8 holes on each side. :thumbup:
Old Dec 1, 2004 | 03:52 PM
1jz gte_ jza70
do the type r's not have side moldings? i thought they were the same color as the car I never noticed.
Old Dec 1, 2004 | 04:04 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
no the type r's don't have the side molding...I took my side moldings off and for temporary i put white duck tape over each hole...doesn't look to bad but i gotta get it filled somehow. Some pics :drool:
Old Dec 13, 2004 | 05:02 PM
1jz gte_ jza70
bondo will take care of that. and you can do it your self just gotta make sure you sand it down to set it flush with the pannel.
