fixing "blotches" in finish on my set of fat fives?
Old Sep 5, 2004 | 02:00 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default fixing "blotches" in finish on my set of fat fives?
i dont really know a good way to explain this, so i took some pictures. basically, can some one tell me how to fix the wheels and make them look good as new? the pics are attatched.
File Type: jpg
File Type: jpg
File Type: jpg
Old Sep 6, 2004 | 06:34 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Old Sep 6, 2004 | 08:25 AM
randomtask77's Avatar
randomtask77
Wanderer
Do they look like stains, or is it like "rust" in the finish? You might want to try some kind of a heavy duty degreaser like simple green or something of that nature. If that doesn't work, try getting some kind of a wheel/metal polish and see if that'll work. If that is to no avail, you might have to get it either professionally cleaned, or the surface of the wheels has to be redone (either remachined or repolished).
Old Sep 6, 2004 | 02:52 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
High grit sand paper (wet) will help get rid of the dark blemish, but in return it also may leave a lesser finish that may not fully blend as well. It will look a lot better though.
Old Sep 6, 2004 | 05:16 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
do i have to sand the whole wheel, or just the blemishes?
Old Sep 12, 2004 | 06:50 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i sanded the whole wheel with 800 grit sand paper, then 1,000. then i repolished them. turns out the only part that really got raw was the blemish spots. so when i polished the wheel, now the wheel has really bright spots, and normal aluminum spots. the bright spots take the place of the blemishes. i think im gonna have to sand the whole thing with lower grit sandpaper, and then repolish the whole wheel.
anyone know what grit sand paper i should use to make the whole wheel raw? thanks
Old Sep 13, 2004 | 05:48 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i think im gonna use paint stripper and take the whole clear coat off. then polish, then clear coat it.
Old Sep 14, 2004 | 02:08 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
clear coat off, sanded up to 1,000 grit.
