Sidemarker template [for JDM DC lights]
Originally Posted by westcoaststyle
You know, when I did my EG9 sidemarkers I actually went out to ebay and found a pic of them on a set of actual JDM fenders. I printed the page and went out to my car to begin the install. Once I had one side done, I made a template from that and did the otherside with the template.
Don't know if it helps, but good luck.
actually the templates from g2ic may work. my brother may have posted some up there. that same template was used on my car with some modification. i don't know if that one was posted. we both have dc sidemarkers installed on our cars. as a note, we noticed that most sidemarkers line up with the back end of the fenderwell to the top of the fenderwell. this is general rule though because i do realize that the eg? has them mounted low. i believe this is to line up with the corners. anyways, the size and placement is very close - it probably won't even be noticable if it's a little off.
EddieK
92+ Civic/EL & Del Sol
15
Jun 20, 2003 05:17 PM
airon
Apr 16, 2003 07:46 PM
