Speed variations
Old Aug 8, 2003 | 09:17 AM
CBlaize's Avatar
CBlaize
Default Speed variations
Does anyone know why speed should change momentarily when under neutral or reduced throttle (trying to avoid more tickets). It's very annoying and Acura is no help at all.
CBlaize
Old Aug 9, 2003 | 01:52 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
If your AC compressor is kicking on or off the clutch can cuase more stress on the motor and cause it kinda slow down. I would have it checked out cuase a new rsx shouldn't do that. Try going with out the A/C on and then try it with it on.. see if it makes a difference.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Aug 9, 2003 | 07:54 AM
CBlaize's Avatar
CBlaize
Thanks. I will check carefully, but don't have much hope because I don't use the AC nearly as much as the winshield wipers (Seattle).
Mike
Old Aug 15, 2003 | 11:23 AM
CBlaize's Avatar
CBlaize
Definitely not the air conditioning. Very frustrating to go lurching down the road and not be able to find the problem.
Cblaze
Old Aug 30, 2003 | 12:26 AM
DAS COW's Avatar
DAS COW
I've noticed the same problem with my RSX. It seems to lurch when the revs are lower (it only happens occasionally though)...
Old Aug 30, 2003 | 07:56 AM
CBlaize's Avatar
CBlaize
It's frustrating because I can't find any pattern except a neutral or reduced throttle. This week we are going to start replacing parts in hopes of finding the solution. If we find solve the problem I will let you know.
Old Aug 30, 2003 | 03:31 PM
Import-Tooner
skoooooie!
Hey, does it do it only when it is cold? or when the motor is to full operating temp. Because, now that I think about it my rsx has done the same thing when I first get in it and don't let it warm up.
SKOOIE!!!
Old Aug 30, 2003 | 08:27 PM
CBlaize's Avatar
CBlaize
So far it has happened slightly more often going north. Other than that, there is no pattern. Hot, cold, doesn't seem to matter.
Old Sep 25, 2003 | 08:51 AM
CBlaize's Avatar
CBlaize
Talked to other RSX owners. The "lurching" seems to be common behavior, although my car apparently has a more severe case than most. Guess I will just have to live with it - but it sure is irritating. Will trade the car in on something that runs smoother next year.
Old Sep 25, 2003 | 05:38 PM
Import-Tooner
skoooooie!
That really is weird that your car does it that bad. I would take it to acura and have them do a diagnostics test on it. Maybe they can figure it out. It should still be under warranty.
SKOOIE!!!
