p1298
Old Jan 14, 2007 | 10:25 AM
HoNda_CeRtIfIed's Avatar
HoNda_CeRtIfIed
Default p1298
I jus dropped a new motor in my friends 2003 Civic Si. I'm throwing a code P1298 electrical load detector high input detected. and i cant figure it out for anything. ANy Input anyone
Old Jan 17, 2007 | 05:37 PM
HoNda_CeRtIfIed
Anybody Have Any Input On this Situation
Old Jan 17, 2007 | 08:36 PM
simplyredvw's Avatar
simplyredvw
There is a service bulletin out on that code. It says that if a p1298 is stored, then the electrical load detector (ELD) may have a faulty solder joint. If you just did a motor swap, I would check all the connections at the fusebox. You used to have to replace the under-hood fusebox to fix it, but replacement ELDs are now available. The P/N for the Civic one is 38255-S5A-003.
Hope that helps.
