Stupid noise...normal? RSX-S
Everytimes the car's parked but the engine still running, there is a noise coming from engine area at rpms; between 700-800 after the cooling fans shut off. Did anyone have this noise?
ThAiLaNd-Land of Smiles
hmmm
Thats wut yu get when yu buy a rebadged Honda Integra that had to have its sterring wheel moved to teh left for american drivers lol. Ha ha ha , good thing i dont live there..Is it an auto or stick,. On these if its an automatic, like Integra Type S here(luxo model) there is a hydrolic rear engine mount . it works off vacuum from the engine, they are made to compensate engine vibration at idle, sometimes if the mount has ruptured, or damaged, it will cause the the small actuaor valve that supplies vaccuum to the mount to make a small rattling, i mean really small plasticcky chatter, not anythin loud but load enough to hear, because this rear mount is active only at idle. Otherwise if the mount is damaged it may be causeing sumthing else to make noise. On my cousins Integra Type S (04) he had 2 issues, he drove to agressive for his auto tranny and damaged his rear engine mount(the electronic vacuum controlled one) causing the valve/solenoid that controls it to make a small chatter as the engine idled because of air flowing back to the valve(the mounts werk on engine vaccuum), Then after his belt tensioner would make noise on and off at idle making a light chattering noise.
