tubro lude
Old Oct 2, 2003 | 08:59 PM
twin3037's Avatar
twin3037
Default tubro lude
alrgiht im researching into a car for my freind taht knows shit about them he like lude's and wants a turbo as he says but he want to have high boost. What engien would be the best for that so basiclly dohc non vtec low compression f22a1 has like 8.8 compression so thats good but what turbo kits are made for it?
Old Oct 2, 2003 | 10:33 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
Default Re: tubro lude
low compression doesn't mean it's better for boost....the higher the better as far as power is concerned, but the lower the CR, the less likely you are going to **** it up....but again, less power...in stock form, they're all about equally as strong....maybe the f22 has an edge, maybe not......if he's gonna build the bottom end first, then get the h22......better head design and that's where power comes from......h22a at 6psi is making over 220whp......h23 at 10psi is making 215whp or so......
Old Oct 3, 2003 | 02:19 AM
ludeboom's Avatar
ludeboom
i agree with fizzy
as usual...i would have to cast my vote for the h22
if your going to build the motor, then you are going to pull the current motor, and if you are gonna do that, you can get an h22 used for like 1300 engine only.
change rods
change pistons
sleeve the block
all this can be done pretty inexpensively (or at least by me it can)
btw f22a1 is SOHC non-vtec
dont buy into that BS about a non-VTEC head being better, all you need is turbo cams (not that much $, especially used).
or some type of custom cam with shaved duration and some tuning
a much bigger issue is the FRM cylinder walls of the h22a when boosting, basically they dont like it, so u will want to get sleeves for reliability, oil control, ring life
extra lift at high RPMS is better for boost, its the duration overlap in VTEC that boost's-thru and causes loss of power
but again its all about tuning
IMO overall an h22a/1 is a stronger and better engine than an h23a1. even for boosting
thats my opinion
~boomer
