Motor Swap?
Old Sep 29, 2003 | 12:08 AM
preludefan's Avatar
preludefan
Default Motor Swap?
Is the motor swap of the 1992 Prelude si 4WS H23 to a H22 v-tec a basic swap or there mods involved?
Old Sep 29, 2003 | 01:39 AM
Tirod's Avatar
Tirod
its one of the more basic ones.. not as basic as b-series swaps though...i understand
Old Sep 29, 2003 | 05:17 AM
machinehead's Avatar
machinehead
its easy. do a search and you'll get all the info you need.
Old Sep 30, 2003 | 10:22 PM
93prelude's Avatar
93prelude
so do you need anything besides the motor? it just bolts right in? same transmission, mounts, ecu...etc. thanks in advance
Old Oct 1, 2003 | 02:08 PM
ludeboom's Avatar
ludeboom
h22a/1 (obd1) is a direct drop in for a 4th gen prelude
imo it is one of the easiest to do
some b series are easier because you can lower the car onto the engine to simplify your life, whereas with the h22a you have to lower the engine in, unless you take the crossmembers off which is a pain
you will need:
h22a/1 engine
ecu
those are the basics
u can use your current tranny
u can use your current axles
u can use all your current mounts
usually the engine+tranny+ecu swap is the best thing to buy
u will also need to run 2 wires from the distributor area to the ecu area for VTEC, you can ground the 3rd VTEC wire to the valve cover or thermo housing if you wish, u will also have to modify the ecu harness to accept these 2 wires, or run the wires into the ecu somehow and solder them to the board.
might i recommend changing your clutch and timing/balancer belts before the engine goes in the car.
it is 100 times easier to do these things when the engine is off the car
good luck
~boomer
