tire offset
Old Sep 22, 2003 | 12:01 AM
clowN's Avatar
clowN
Default tire offset
anyone have anyidea what is the correct offset to clear the body, in the front and the rear?
i have
toyo FZ4's
Rim Width Range (inch): 7.0-7.5-8.5
Overall Width (inch): 8.8
any one have any idea if these will clear the body in the front?
i need to buy new tires from the back, because they rub on the body, they are
215/45/18
anyone know which i can buy for the rear, that wont hit the body, and tuck in?
Old Sep 22, 2003 | 08:22 AM
monkey's Avatar
monkey
#212
from preludeonline.com
There seems to a lot of questions regarding tire size, offset, and lug pattern ---> so here is a list of suggested tire sizes and offsets, along with the lug patterns for each generation
Tires
Other sizes can be used, but these will be the majority of sizes used.
Where "Overall Diameter is Larger" is noted there maybe a problem with cars that are lowered.
These are only tires that are close to stock O.D., the offset of your wheels needs to be correct in order to prevent rubbing issues.
235 Width Tires are Not Recommended
Larger Diameter Wheels with cause your Speedometer to Display Slower than you Actual Speed
Smaller Diameter Wheels with cause your Speedometer to Display Faster than you Actual Speed
5th Generation (1997-2001)
205/50/15 - Better Acceleration, Overall Diameter is Smaller
205/55/15 - Recommended 15” Size Tire w/ 6.5" wide wheel
215/50/15 - Larger Contact Patch, Better Acceleration, Overall Diameter is Smaller
225/45/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is recommended, Overall Diameter is Smaller
225/50/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
205/50/16 - Stock Size, Recommended 16” Size Tire
215/45/16 - Larger Contact Patch
215/50/16 - Larger Contact Patch, Overall Diameter is Larger
225/45/16 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
215/40/17 - Larger Contact Patch, Recommended 17” Size Tire
215/45/17 - Larger Contact Patch, Overall Diameter is Larger
225/40/17 - Even Larger Contact Patch, Very Limited Selection of Brands
215/35/18 - Larger Contact Patch, Small Profile means Less Protection for Wheels
215/40/18 - Larger Contact Patch, Overall Diameter is Larger
225/35/18 - Even Larger Contact Patch, Recommended tire size for 18x7.5" with at least a +48mm offset
225/40/18 - Even Larger Contact Patch, Overall Diameter is Larger, Not Recommended if car is Lowered
4th Generation (1992-1996)
205/55/15 - Stock Size, Recommended 15” Size Tire
205/50/16 - Recommended 16” Size Tire
205/40/17 - Overall Diameter is Smaller, Not Recommended w/ 7.5" wide or larger wheel
3rd Generation (1988-1991)
195/60/14 - Stock Size
205/55/14 - Larger Contact Patch, Overall Diameter is Smaller
205/50/15 - Larger Contact Patch
215/45/16 - Even Larger Contact Patch, Overall Diameter is Larger
205/40/17 - Larger Contact Patch
Offset
These are only recommendations based upon comments from members of the board.
4th & 5th Gen. Stock = 6.5" Wide Wheel w/ +55mm
3rd Generation Stock = 5.5" Wide Wheel w/ +45mm
Note:
Most people who lower 5th Generation Prelude w/ aftermarket wheel equipped need to trim off a small piece of the rear bumper cover inside of the wheel well. You can trim is using a dremel, grinder, a file (take longer obviously), etc --- it is only plastic. If you put your hand inside the wheel well you will see what I'm referring to. See image below:
6.5" Wide Wheels w/ 4th & 5th Gen.
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen.
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen.
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen.
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.
Stock Lug Pattern
5th Generation ::: 5x114.3
4th Generation ::: 4x114.3
3rd Generation ::: 4x100
Note: If you see any error let me know and I'll change them, I don't want to be putting the wrong information out there. If I could get more information on the 3rd Generation tire and offset sizes that would be nice, but there just isn't as much information.
