Freinds lude wont start!
Old Sep 5, 2003 | 02:34 AM
s13zilvia's Avatar
s13zilvia
Default Freinds lude wont start!
I used the search function and came up with nothing, so basically the car is getting fuel, but doesnt seem to be getting any spark. Is there something on the preludes that is a common occurence of going bad, any help would be appreciated. The car is a next to the last generation, and I believe the engine is a h22a, but not totally sure, sorry I dont know more, thanks for the help.
Old Sep 5, 2003 | 02:46 AM
THATPRELUDEGUY's Avatar
THATPRELUDEGUY
I suck!
If it's a 5th Gen, 97-01 it could be a fault ignition switch, there was actually a recall on that.
Old Sep 5, 2003 | 04:21 AM
s13zilvia's Avatar
s13zilvia
No its a 4th gen, so I guess that wouldnt be it, any other suggestions, thanx.
Old Sep 5, 2003 | 07:19 AM
prelude1897's Avatar
prelude1897
Did you guys do a motor swap? If so, did you make sure all the wires were hooked up right and in the right spot
Old Sep 5, 2003 | 07:24 AM
Mr.Badguy's Avatar
Mr.Badguy
Sometimes my car does that too. But I usually can get it started after a few minutes. I was thinking maybe it was the gas Im using or the fuel injector may be clogged or something. Plus sometimes when that happens I open the gas tank and the tank makes a sound like air is rushing in. Like the tank is making a vacuum. I have no idea why though...
Old Sep 5, 2003 | 08:28 AM
s13zilvia's Avatar
s13zilvia
Thanks for the replies guys, kep em comin, I need all the help I can get,peace.
Old Sep 5, 2003 | 10:56 AM
shawmutt's Avatar
shawmutt
I recently posted this after I fixed my lude, see if this helps:
https://www.honda-acura.net/forums/s...threadid=92076
Old Sep 5, 2003 | 06:33 PM
s13zilvia's Avatar
s13zilvia
Can you tell me where exactly under the dash the main relay is, thanks for all the help.
