Engine Issues
Old Sep 1, 2003 | 09:33 PM
HavocR's Avatar
HavocR
Default Engine Issues
OK, my 93 Prelude Si 2.3 has been running fine at 106k miles then one day I'm driving and around 3000 rpm it cut in and out a couple times. My clutch is bad, so I thought it was just a little slippage.
Couple days later, it cuts in and out again and the car starts to rough idle, and a lot of back fire at idle, then it stalls at idle unless the revs are kept up. At one point, the car wouldn't even restart until I waited for awhile. Anyways, after awhile it ran normal again.
Thought it was my egr, since I was getting a code 12 (egr failure) on long freeway drives, so I plated the egr, the prob went away but then came back in a couple hours of driving.
These probs are really occasional, but I am thinking along the lines of fuel injector or fuel pump probs????
The coil, plugs, wires, fuel filter, cap, rotor are all new. The distributor is about 2 years old. Timing was also recently done, as with valve clearances. Any input would be great, sorry for the long post.
Old Sep 2, 2003 | 10:03 AM
machinehead's Avatar
machinehead
i had that problem on my old nissan stanza, then it just went away one day.
