need help with suspension
Old Aug 30, 2003 | 01:16 AM
ryclee78's Avatar
ryclee78
Default need help with suspension
ok for suspension-wish, i only have h&r springs which lower it 1.5".. my shocks have been leaking so i need to get them replaced and also i want a better ride.. my friend has suggested kyb agx or tokico adjustables.. the only problem that i have is that i've looked for the shocks for my car and all of them say "excl-sh".. can anyone out there give me info about some shocks that will work?? thanks..
Old Aug 30, 2003 | 07:08 AM
jc836's Avatar
jc836
You will have a bit of difficulty finding aftermarket shocks to use with stock springs on an SH. The stock front ones are specific for each side. The rear shocks are identical to the BASE. So your real problem is what will work up front.
You can use Ground Control or Skunk2 sleeves and springs with Koni shocks as one possible solution.
Old Sep 1, 2003 | 02:57 PM
HotLude93's Avatar
HotLude93
The One And Only
idk, much about suspension but i bought my spirngs and shocks of modacar.com i got a suspension package you know you cant go wrong that way. but i dont think my 93 has such specific needs as your prelude.
Old Sep 1, 2003 | 02:58 PM
HotLude93's Avatar
HotLude93
The One And Only
anyway good luck and remeber when putting in neons make sure you know wtf your doing and dont pull a mr. houtlude93, cuz that would be bad.
