starting problems due to fuel system?
Old Aug 13, 2003 | 09:50 PM
LT's Avatar
LT
The deer had to die!
Default starting problems due to fuel system?
my friends 92 lude si didn't start for 15 minutes today. he checked the plugs and stuff, then opened the gas cap and the car started up. Could it be vapor lock or a vapor locked dirty fuel filter?
Anyone have a similar problem to help him out?
Old Aug 18, 2003 | 08:35 AM
Mr.Badguy's Avatar
Mr.Badguy
something like that happened to me once or twice. But i think that making sure i always have plenty of gas helps. Was his car low on gas like about 2-3 bars?
Old Aug 18, 2003 | 11:51 AM
shawmutt's Avatar
shawmutt
Are all these things true:
1. The interior was hot
2. The car cranked fine, but wouldn't start
3. The car started when the interior cooled down a bit
4. After the car started it ran fine
If all of these are true, you might have a bad main relay. Listen to the car when it is cool outside. When you turn the key, all the dash lights go on, including the engine light. Listen for the click when the engine light goes off. That is the main relay. If you don't hear this click when the interior is hot, the main relay needs to be replaced. It is $60-$70 from the dealer and very easy to replace.
