Buffing, Waxing help!
Old Jul 16, 2003 | 08:17 AM
Pelka's Avatar
Pelka
::..Prelude..::
Originally posted by ProjectWidow
well than i guess yours werent as bad as mine cause i dont think buffing or waxing will help me. But if you said it worked on yours then goodjob.
Yea they aint that bad but could use a nice coat of paint... ill save a couple grand... that means no rims for a while :sad: . Its ok tho one thing at a time right?
Old Jul 16, 2003 | 09:28 AM
machinehead's Avatar
machinehead
my lude is all faded on the moon roof but the rest of the roof is fine. go figure :/
Old Jul 16, 2003 | 10:47 AM
Pelka's Avatar
Pelka
::..Prelude..::
Honda does not know how to paint plastics...
Old Jul 23, 2003 | 11:47 AM
Pelka's Avatar
Pelka
::..Prelude..::
Originally posted by redgoober4life
Mothers makes a good bar. Around $17 for the clay bar and the lube (quick detailer). It will get the paint smooth, but won't do anything for scratches or luster. It's a good step though if your paint isn't as smooth as glass.
Clay Magic is also good. Walmart may even carry it in your area. I highly suggest a polymer-based sealer wax to a carnuba. properautocare.com has a few (Klasse is good, not the easiest to use, Blackfire is easy to use and good). If you want to go locally, Meguires sells one. I think it's #20. I forget. Klasse and Blackfire come with a polish I believe, the Meguires you would have to use one of their polishes after clay baring before you apply it. polymer's last a lot longer. Hope this helps.
Ok... little confusing but its ok... ok so im going to first buy the clay bar, then im going to buy a quick detailer in the spray bottle, then im going to buy a 3 step wax kit from Meguiers. Where can i get a polymer-based sealer wax?
