Valve adjustment help
Old May 30, 2003 | 01:02 PM
HavocR's Avatar
HavocR
Default Valve adjustment help
I recently adjusted my valve clearance on my 93 Prelude 2.3. I did it to my manual's specs which was .007ex and .004int. I double checked the clearances then took it for a drive. It ran fine, but when I popped the hood after it was warmed up, it smelled like something was burning. I am worried that I might have done the clearance too tight burning the valves.
Any input would be great.
Old May 30, 2003 | 01:07 PM
4bidden's Avatar
4bidden
Did you make sure to do the valve adjustment when the motor is <100 degrees? Its best to let it sit overnight.
Pop it open and double check your gaping when the motor cools off.
Old May 30, 2003 | 02:26 PM
honda guy's Avatar
honda guy
you won't smell burn't valves did you put seeler in the corners of each cam ? may just be oil that ran down the back of the head.
Old May 30, 2003 | 08:32 PM
HavocR's Avatar
HavocR
Yeah, I did it on a cool motor, also it is not a burning oil smell, more of a burning plastic smell, but not quite.
Old May 31, 2003 | 06:30 AM
honda guy's Avatar
honda guy
maybe you ran over a plastic bag and its stuck melted on your exhaust.
Old Jun 1, 2003 | 08:58 PM
4thGenReady2Go's Avatar
4thGenReady2Go
Throbbing Member
you're sure it was cold, and not just cool? Usually the best thing to do is let it sit for a good 12-24 hours. You probably did that part right anyway. Lol, cross your fingers, maybe it was just a plastic bag.
