clock/radio not working. shorted out...
Old May 19, 2003 | 02:26 PM
epoxy's Avatar
epoxy
Regulator
Default clock/radio not working. shorted out...
hm..i rigged up the switch to reset my ecu a few weeks ago. I wanted to light up the switch so i grounded the switch where it was supposed to be grounded at. I accidently hit the wire that was part of the ECU circuit.
Now my clock doesnt work, radio doesnt turn on, and that's all i've found right now.
I was wondering if i blew a fuse or something somewhere?
http://www.ntpog.org/mods/fifth-afc/ecu.shtml (write up to the wiring)
Old May 19, 2003 | 03:10 PM
epoxy's Avatar
epoxy
Regulator
nm.. just a fuse blown under the hood.
Old May 20, 2003 | 09:06 AM
prelude1897's Avatar
prelude1897
Had to only be a fuse. Usually those will go first before shorting out wires in your car
Old May 20, 2003 | 09:21 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Any idea how accurate those instructions are for a 96 prelude?
Old May 20, 2003 | 03:47 PM
epoxy's Avatar
epoxy
Regulator
it's just one wire. they are (supposably) in 96+ preludes. it was easy
Old May 25, 2003 | 03:37 AM
drift's Avatar
drift
Flaccid Member
you should try disconnecting the negative terminal on your battery before attempting any electrical modifications.
you're lucky you didnt fry the ecu.
