Help, Check Engine light on after install of High-Flow Cat
Guest
Posts: n/a
Hey Guys, I just installed a High-Flow catalytic Converter on my Lude, and now my check engine light has come on. I have a 5th gen lude, is there any way I can turn this off permanently, or is there a part or company I can contact that makes a part that will trick the ECU inot thinking my car has a factory cat on it?
well I dont know a lot in that area, but I talked to a guy at a shop who did stuff like that on hondas/acuras, and said that he knew how to trick the o2 sensors by putting a resistor between them to make them think they were getting the correct power. Since the o2 sensor is plugged into your cat, than that is the most logical reason why the check engine light is on. It could have just tripped the check engine light inadvertantly with the new install, thats why before you should look into solutions, try resetting your ECU by pulling your negative terminal off on the battery, or the clock fuse in the engine bay fuse box. If the problem is still there than the check light will come back on, if its gone then the check light will stay off, also, is your check engine light still on? If so do you know how to pull it to where you can find out exactly what the code is? If you dont know Ill tell you how...... Also, did you do the install or someone else? Make sure the O2 sensor is screwed in fully and correctly.
Guest
Posts: n/a
sounds like either they messed up the o2, or its not properly plugged in..... also, some cats will cause the CEL light to come on, there are some shops like I said, who know how to trick the o2 sensors into thinking everything is stock w/a resistor....I dont know the exact procedures to doing that so you would have to ask someone who has done that before.....
