Prelude running a little hot
Old Mar 21, 2003 | 04:51 AM
Ih8pigz's Avatar
Ih8pigz
Default Prelude running a little hot
Do h22a engines run hotter than normal because i noticed yesterday while sitting in traffic for awhile that my car got hotter than usuall. I just got the car 2 weeks ago and haven'
t really figured out everything about. it was 60 thoughsand on a 93 prelude vtec. I was thinking i mihgt have to replace the headgasket already or flush the cooling system. The antifreeze/cooling is filled to the max limit so that isn't the problem.
Old Mar 21, 2003 | 05:15 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
I doubt the headgasket is gone at 60K... of course, anything is possible... but my bet is that the coolant hasn't been changed in a LONG time, and has probably lost most of its cooling properties. Try a flush first.
Old Mar 21, 2003 | 05:11 PM
94prelude_v-tec's Avatar
94prelude_v-tec
Punk Rock
flush the coolant and replace the thermostat. it will cost under $20
Old Mar 23, 2003 | 04:49 PM
preylude99's Avatar
preylude99
if it was the headgasket, youd have worse symptoms then it just getting a little hot. when you say it gets a lil hotter, how much are you talking about when it is fullywarmed? Like the other guys said, the problem is either in the coolant or the thermostat, good idea to do both at once. The thing about the thermostats is, while a car may have low miles, it is still 10 years old so sometimes in the thermostats the spring gets stuck open (which causes the car to run cold) or the opposite.
Old Mar 23, 2003 | 04:59 PM
Ih8pigz's Avatar
Ih8pigz
The digital gauge normal reads half but when it sits for awhile it goes to 3/4. I have a mugen thermostat on order so i'll flush it when i get it.
Old Mar 24, 2003 | 09:56 AM
IHIPrelude94's Avatar
IHIPrelude94
You said you were sitting in traffic when this happened? If so then that could just be normal. You need air flow through the radiator to keep the engine cool. When that happens, just put your heater on full blast to keep the temp from rising any higher. It'll make it crappy for you, but at least your car won't start to overheat.
~Peace
Old Mar 30, 2003 | 07:19 PM
Armadillo's Avatar
Armadillo
93 SI 4WS
Do your fans kick on?
Old Mar 30, 2003 | 10:35 PM
preylude99's Avatar
preylude99
good question armadillo, if yur fans arent kicking on then that could be why also, cause if you have the engine off with the ignition on and have the fans running, you can see the temp drop a little bit sometimes.....also, when you replace the thermostat, take a look at your stock one and see if the spring is collapsed...
