Aftermarket wheels and offsets
Old Feb 11, 2003 | 09:41 AM
ksorokan's Avatar
ksorokan
Default Aftermarket wheels and offsets
Are there any aftermarket wheels that come close to matching the '98 Prelude's 55mm offset? If there aren't any close, how do you prevent the tires from rubbing on the fenders when the car is loaded down?
Old Feb 11, 2003 | 01:23 PM
THATPRELUDEGUY's Avatar
THATPRELUDEGUY
I suck!
It's pretty much been shown that on a 7" wheel with the appropriate tire you can safely run as low as 45mm. If you're not lowered I'd say you can go even more, perhaps 42mm. Some have run 40mm offset but personally I think it's way to boderline to bother if buying new wheels.
As for 55mm offset wheels I'm sure you can find a few sets of japanese wheels that will have this offset.
Any particular setup your thinking about for wheels/tires?
Old Feb 11, 2003 | 04:10 PM
boilers's Avatar
boilers
Don't run a +40mm offset tires if you're lowered. I'm lowered on neuspeed with a +40mm offset and I rub in the back. But after shaving the plastic thing on the fender, it's all good now. I think it's best to have at least +45mm.
