h23 v-tec part 2
Old Feb 4, 2003 | 12:21 PM
94prelude_v-tec's Avatar
94prelude_v-tec
Punk Rock
Default h23 v-tec part 2
If im right all h series motors have the same bore. So when i rebuild my h22 can i put h23 crank and rods in it with type-s pistons? If so i think this would be one rad motor! :naughty:
Old Feb 4, 2003 | 01:22 PM
drift's Avatar
drift
Flaccid Member
yes, it would work.
the extreme rod/stroke ratio of the H23 rotating assembly will create extreme bearing stress at high rpm. in addition, the rod/stroke ratio's influence on piston speed will reduce overall high rpm breathing ability, reducing total output in a naturally aspirated condition.
Old Feb 5, 2003 | 09:30 PM
94prelude_v-tec
Punk Rock
what a let down. oh well thanks
Old Feb 6, 2003 | 05:38 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Can it be corrected to not reduce as much or actually increase performance with diffrent internals?
Old Feb 6, 2003 | 05:24 PM
drift's Avatar
drift
Flaccid Member
rod/stroke ratio for the stock H23A is 1.49:1 ideally, you want to be as close to 1.75:1 as possible. it's the "perfect" compromise between revvability and torque.
you can have custom rods made that are longer than stock, and have custom pistons made with relocated wrist pin holes to use the rods without the piston ringpack going above the block's deck. the most you could get to would be about 1.53:1 before the wrist pin placement on the piston interferes with oil ring seating.
you can also add material to the deck of the block, essentially making it taller so you dont need to use relocated wrist pins on the pistons... you can use standard wrist pin location with rods as long as you want depending on how much taller you make the deck. then you simply deck the block flat, stuff it, and let her rip. JG Engine Dynamics has done this for CR/VTEC setups to give it a better rod ratio while maintaining the added displacement.
essentially, there's ways around it, but it's all on how much you want to spend. in this case, if you have to ask how much, you probably cant afford it.
