too rich....
Old Feb 3, 2003 | 07:45 AM
preylude99's Avatar
preylude99
Default too rich....
my lude is running a lil too rich, are there any ways to tune it so it will not run as rich? I know the v-afc may be one way, but will that allow me to have the air/fuel ratio tuned correctly or not? some people say yes some people say no, any feedback will be appreciated
Old Feb 3, 2003 | 08:55 AM
epoxy's Avatar
epoxy
Regulator
you can make the fuel curve optimum for the v-afc if you get it dynoed.
basically, they will play with it, looking at a hp and torque graph each time, and leave it at the setting where it makes the most power. usually optimum power is ~13.3 - 13.5 i believe
Old Feb 3, 2003 | 10:21 AM
preylude99's Avatar
preylude99
someone told me i can get an adjustable fuel pressure regulator and get an air/fuel ratio gauge and do it that way...... would that be safe or would I still be in danger of making it run too lean or too rich w/o a dyno test?
Old Feb 3, 2003 | 12:11 PM
epoxy's Avatar
epoxy
Regulator
well you'd have to adjust the modifier. so.. you'd be depriving yourself of a afc. that would be better.
if you spend money on your car, you might as well make it worth it.
i have a b&m fuel modifier and vafc... the fuel modifier wouldnt make it run more lean/rich though
