92 Prelude AC Cutoff Question
Old Jul 28, 2008 | 11:45 AM
mkhordiav's Avatar
mkhordiav
Default 92 Prelude AC Cutoff Question
Hello Everyone,
This is my first post, so please forgive me if I'm posting in the wrong area!
I own a 1992 Prelude w/ 133k miles. Up to now, the AC worked perfectly (with the original R-12 refrigerant) I moved here from Denver to Tulsa, and now the AC works only part of the time. In the morning when ambient temp is lower than 90 degrees, it blows ice cold. But when the temperature is higher than that, it only partially gets cold. I've had the charge checked out, and it's fully charged with no leaks. The compressor engages, but it sounds like a low-pressure cutoff switch maybe? If I'm driving and the AC cuts out, I can turn the AC button on and off several times, then it "tricks" it into cooling, if only for awhile. Any tips on diagnosing this? I've got plenty of mechanical knowledge as far as drivetrain goes, but AC issues have me buffaloed!
Thanks!
-Jeff
Old Jul 29, 2008 | 02:44 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
I had the same problem in my Prelude...never really got "cold" but it was colder than outside lol....
Old Jul 29, 2008 | 07:45 PM
stereo's Avatar
stereo
next time when it acts up pop the hood and see if the compressor is coming on as i've seen quite a few compressors with a bad shaft seal what happens is it works fine when cold but after it heats up on a hot day the oil leaking from the shaft prevent the clutch from engaging only way to find out is to put dye in it or pull the clutch cover..
Old Aug 4, 2008 | 07:28 AM
mkhordiav's Avatar
mkhordiav
**bump**
