96 Prelude ABS Light On
Old Nov 20, 2007 | 06:46 PM
hi_volume's Avatar
hi_volume
Default 96 Prelude ABS Light On
I have a 96 Prelude Si with about 65K. Starting at about 10 second of driving, the ABS light comes on (not when I press the brake pedal, just when driving). My brake fluid level is good, and I've cleaned the ABS sensors at each wheel. I've also just replaced the ABS module pump, with a working used one (the dealer said according to the code, this needed to be replaced). I am at a loss for what to try next. Any help would be very much appreciated. Thanks
Old Nov 21, 2007 | 08:20 PM
nemesis25's Avatar
nemesis25
What is the code?
Old Nov 21, 2007 | 08:57 PM
hi_volume's Avatar
hi_volume
I don't know how to read the code myself, but took it to the dealer.
Old Nov 25, 2007 | 02:04 PM
hi_volume's Avatar
hi_volume
I just found my receipt from the dealer, it is reading a "code 1". Thanks
Old Nov 26, 2007 | 09:57 PM
nspec_Cd5's Avatar
nspec_Cd5
code 1 is for the faulty abs motor. check ur fuse under the hood. abs has its own fuse box. hope fully thats the only thing wrong. if not then check the fluid level in teh pump
