burning oil
Old Oct 16, 2007 | 12:31 AM
russianpsyco's Avatar
russianpsyco
Default burning oil
There is some oil burning when I drive at higher speeds, like on the freeway. I dont smell anything while driving but when I get off an exit and stop i smell it pretty bad. It doesnt do that at slower speeds. I have no clue as to what needs to be looked at or changed. Anybody know whats going on?
Thanks in advance
Old Oct 16, 2007 | 05:29 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Can you see it coming out of the exhaust? and is it a dramatic loss of oil or just 1/2 qt before oil change?
Old Oct 16, 2007 | 05:39 PM
russianpsyco
No, i doesnt come out of the exhaust and its only about 1/2 to 1 quart between oil changes. Could it be something else burning?
Old Oct 17, 2007 | 05:24 AM
F22B Prelude
Rachel Bilson
Preludes have been known to burn oil at higher rpms....if you don't notice a leak on the head or plugs...and the coolant looks good...I would say its normal
Old Oct 17, 2007 | 10:05 AM
russianpsyco
I do notice that there is always a drop of oil on the drain bolt. So im pretty sure its leaking from somewhere but I have no idea where its coming from. When I change the oil i tighten the bolt really well so I know its not leaking. The oil filter is also tight but could it be leaking from somewhere around the filter area? Since the filter is directly above the exhaust I think its dripping onto my exhaust and thats why its burning.
Old Oct 17, 2007 | 11:32 AM
F22B Prelude
Rachel Bilson
Look around the rear main seal and the pan gasket....mine had a leak around the rear main seal, but it wasn't as bad as you say yours is
