emission problem
Old May 15, 2007 | 07:56 AM
98_prelude_kb's Avatar
98_prelude_kb
Default emission problem
Hello Honda prelude experts,
I urgently need someone's help/suggestion to fix the emission problem that I'm experiencing with my Honda Prelude 1998 (SH).
I went for the emission test and it didn't pass!!!!
First test result looks like:
HC ppm - PASS
CO % - PASS
NO ppm - FAIL Reading 780 (Limit 450)
GAS Cap - PASS
All others - PASS
Second test resultlittle improvement in `NO ppm`)
I replaced with new PVC valve and went for second test.
HC ppm - PASS
CO % - PASS
NO ppm - FAIL Reading 766 (Limit 450)
GAS Cap - PASS
All others - PASS
Third attempt(got worst in `NO ppm`)
Before I went for the test, I did following to the car:
- flushed the engine and changed engine oil
- Replaced the distributer cap, plate and wire
- Replace the spark plugs
- Cleaned the EGR valve with Honda Carburetor/Combustion chamber cleaner(
(I test for leak by sucking the air - valve seems to have no leak)
- Used the octane booster before I fill the tank
- Sprayed the Honda Carburetor/Combustion chamber cleaner into the air intake hose and drove about 20 km to the `emission test center`.
What happened ? It FAILED badly.
Result looks like :
HC ppm - PASS
CO % - PASS
NO ppm - FAIL Reading 809 (Limit 450)
GAS Cap - PASS
All other are - PASS
Please help.
Old May 15, 2007 | 08:43 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Do you have a check engine light?
Old May 21, 2007 | 10:28 PM
RboYi's Avatar
RboYi
catalytic converters help break apart NO and O2 molecules, and reduce NO emissions
