idle problem...Err
Old Feb 12, 2007 | 11:32 AM
91LudeSi's Avatar
91LudeSi
Gsxrmarine
Default idle problem...Err
Ok so my car is driving me nuts. I start it up and the idle keeps jumping up to 2-3,000rpms and bounces back to 1,000. I know it is the way the car warms up when it is really cold, but last couple of days it keeps going even after it is fully warmed up. I know it has something to do with the some device in the intake manifold... I searched for awhile and kind of get it, but need alittle more input from you guys so I can fix the problem. By the way my mods are V2 AEM intake, Dc header, and a custom apexi WS2 (no catwith 2.25'' strait pipping from the header back) Thanks guys.
Old Feb 12, 2007 | 12:27 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
IACV
Clean the screen or bleed the coolant to make sure you don't have anyair
Search for the rest
Old Feb 12, 2007 | 12:49 PM
bob01721's Avatar
bob01721
Yeah, I agree with the previous poster. It does sound like there's air in the coolant. The temp sensor is at the high point of the cooling system -- where air bubbles will migrate. As the bubbles move under and then away from the sensor tip, the sensor reports "cool" and then "hot" and then "cool"... so the PCM keeps changing from cold idle (high) to warm idle (low) speed.
Bleeding the cooling system should fix it.
Old Feb 12, 2007 | 01:42 PM
91LudeSi's Avatar
91LudeSi
Gsxrmarine
ok I am going out now to try that thanks. what about resting the computer?would that help?
Old Feb 12, 2007 | 01:48 PM
F22B Prelude
Rachel Bilson
You could try that? but it prolly won't work
Do you have a check engine light?
Old Feb 12, 2007 | 08:14 PM
michael2fly's Avatar
michael2fly
my lude is going thru the same problems. i found out that it is my eacu. so i tryed cleaning it and it still occured, i'm replacing the engine which is a little extreme but my engine has 215000 miles on it so you see my reason for replacement. what i was told was to replace the iacv if i wanted to keep the engine. i heard that iacv's going out on honda's isn't uncommon at all. good luck with it.
Old Feb 17, 2007 | 06:00 PM
91LudeSi's Avatar
91LudeSi
Gsxrmarine
ok changed the antifreeze and rest the computer... still nothing. I did some researched the IACV figure its the problem. But I still need some help with where it is and how it works, so I can learn why my car has its problem. Thanks guys
Old Jul 22, 2007 | 08:30 AM
shawnhu's Avatar
shawnhu
Jus a follow-up, has the problem been fixed? It's quite possible that it could be the Fast-Idle control valve as well.
Old Aug 8, 2007 | 08:33 AM
CLSOHCER's Avatar
CLSOHCER
I have that problem because my EGR is clogged, did they have those in the early models?
