Rack and pinion
Old Jan 25, 2007 | 08:30 PM
Niceprelude's Avatar
Niceprelude
Default Rack and pinion
anyone change thier rack and pinion on the prelude and the steering wheel become loose . what is the problem.Please help out.
Old Jan 26, 2007 | 06:41 PM
Niceprelude
guess no one has done that.
Old Jan 31, 2007 | 12:19 PM
asheylarry's Avatar
asheylarry
what do you mean its loose. did you do it yourself?? make sure the rack is firmly mounted to the car. make sure that the steering shaft is properly attatched to the rack. finally make sure that all tie rod ends (inner and outer) are tight.
Old Jan 31, 2007 | 12:21 PM
asheylarry's Avatar
asheylarry
and go have it aligned. most shops will inspect a front end for free. once its on a hoist it should be easy to tell. if you cant take it to a shop. jack up the front and look at all steering components while some turns the wheel back and forth
Old Jan 31, 2007 | 09:25 PM
Niceprelude
The shop did the work did 4wheel alighment stated the work is fine.
Old Feb 1, 2007 | 03:35 PM
asheylarry's Avatar
asheylarry
maybe its just the feel of a new rack. but if you are unsure of the work try taking it somewhere else. you can also jack up the front like i said before and have a buddy jiggle the wheel back and forth and look for any slop
