5th gen ABS is disabled and ABS light is on
my ABS light is on and i have no clue what it is for..... i did that CEL code thingy. and it flashed awkward.. i had a code throw out
(i turned key to ignition and light was solid at first then turned off after)
Flashes long-short-short-short
meaning code was 1 3... but in the FAQed section is said it wouldnt flash long.. all only short flashes.. any answers???
example:
- Plug in the jumper, turn on the key. ABS light comes on for a couple seconds then off for a couple seconds. That isn't part of the code.
- Short flashes for the first digit of the code.
- Short pause.
- Short flashes for the 2nd digit of the code.
- Long pause.
- Repeat the code or display another.
example:
- Short pause.
- Long pause.
