Low Beams
Old Oct 3, 2006 | 09:39 AM
troyb207's Avatar
troyb207
Default Low Beams
On my way into work this morning I had my parking lights on until I got out of the garage and then when I turned on my headlights they came on for about 20 seconds and both went out. I tried turning them on and off and nothing. The parking lights and high beams still work and all fuses are good as well. Anyone have any ideas?
Thanks
Old Oct 3, 2006 | 10:25 AM
Omie's Avatar
Omie
ew n!gg@ u g@y
replace the bulbs, the low beams blew out
Old Oct 3, 2006 | 10:29 AM
troyb207's Avatar
troyb207
Would they both blow out at the same time though? I was thinking that the last time I replaced them i did both low beam and high beam at the same time but I never heard of them both going at the same time before. I'll give it a shot though.
Thanks
Old Oct 3, 2006 | 10:30 AM
Lynxx's Avatar
Lynxx
Methanol Drinker
The likelyhood that both low beams blew out at the exact same time is damn near impossible (though I guess it could happen).
What year model is your Prelude? Are you using aftermarket lamps (5000K Zenon, etc)? Have you looked at the fuses under the hood as well?
Old Oct 3, 2006 | 10:31 AM
troyb207's Avatar
troyb207
It's a 97 and all the fuses are good. If I remember right they are the superstars that I put in.
Old Oct 3, 2006 | 10:41 AM
Lynxx's Avatar
Lynxx
Methanol Drinker
Check to see if you're getting power to the low-beams and, if not, check your headlight relay. It could also be your dimmer switch or dimmer relay, but when one of those goes out, it usually happens when you click from bright to dim, not just sitting still.
Old Oct 3, 2006 | 10:59 AM
troyb207's Avatar
troyb207
with this relay which one would it be. There is a couple of them in the fuse box and I want to make sure I got the right one
Old Oct 3, 2006 | 09:02 PM
stereo's Avatar
stereo
try replaceing the bulb first as H1 do blow out often .
