Reverse Problems
Old Sep 25, 2006 | 08:04 AM
liquidSeks's Avatar
liquidSeks
Default Reverse Problems
i got a 00' prelude everything has been kept uptodate for maintence except i haven't got a tranny flush in awhile... couple days ago all my gears worked fine... then my friend drove it for 20 minutes... the next morning when i drove it... the reverse no longer worked... could i get any help on what the problem is?
Old Sep 25, 2006 | 06:42 PM
SirHybrid's Avatar
SirHybrid
is it an auto?
if so, you may be fuuuuuuuuuuuuuuuuuuuuuucked. If it is manual, maybe not as bad, but still not good. You need more details for anybody to help you. What exactly is going on? Will it not go into gear, or will it grind, or what?
Old Sep 26, 2006 | 03:59 AM
vassil3427's Avatar
vassil3427
Did you ever have the fluid changed??? If not and you have a bunch of miles, and your friend was hot-doggin it...he may have screwed up your tranny...Read my post https://www.honda-acura.net/forums/s...97#post3158297 about the SS tranny. Actually reverse not working is one of the first signs your trannies goin out.
BTW, if you have it changed, drain and fill, flushing will probably ruin it for sure.
Old Sep 26, 2006 | 06:51 AM
liquidSeks's Avatar
liquidSeks
it is a manual indeed, it worked fine, it has had tranny flush before jsut havent got one lately,
Old Sep 26, 2006 | 06:06 PM
SirHybrid's Avatar
SirHybrid
Maybe he shifted from 5 into R and killed the synchro and gear.
Old Sep 26, 2006 | 07:11 PM
vassil3427's Avatar
vassil3427
I bet he did what I've heard of before, rolling forward and shifting it in reverse, or possibly just forcing it in reverse. He probably bent one of the shift forks.
