88 prelude intake manifold?
Old Sep 5, 2006 | 11:18 PM
Darkhonda's Avatar
Darkhonda
Default 88 prelude intake manifold?
Anyone know who sells a good after market, or really anything better that will accept my skunk2 68mm throttle body" Or will the stock intake manifold work fine ? And not that it is a big difference but the car is a 89 not an 88 2.0si
Old Sep 7, 2006 | 09:02 PM
Kai's Avatar
Kai
Rotorphile.
B16A intake manifolds can be adapted to JDM "goldtop" Accord version B20A and USDM A20A engines... check into it, you may be able to adapt the B16A manifold to a US Prelude version B20A. Many things are different between the goldtop B20A and the 'lude version, but the manifold bolt pattern may be the same.
Old Sep 12, 2006 | 05:03 PM
Darkhonda's Avatar
Darkhonda
alright thanks for some direction
Old Sep 16, 2006 | 06:13 AM
Omegasupreme's Avatar
Omegasupreme
With the pk2 b20a you have to worry about the lean on the motor. You can make a gsr manifold pretty easy, but the runner are to long. So you'll endup running into the rear cross member if you not careful.
