92 prelude drive 4 flashing
Old Aug 28, 2006 | 12:22 PM
Xcore_star's Avatar
Xcore_star
Default 92 prelude drive 4 flashing
ok when i go to start my car sometimes it doesnt wanna start.
when you go to start it the p for park is lit up....
but the d4 is flashing.
and when i try to start it it just starts but doesnt click over.
and it doesnt need to be jumped or anything.
you just have to sit there and wait till it stops flashing.
and sometimes it can take up to 4 hours.
can anyone help me or know whats wrong with my car??!?
cause no one seems to know.
Old Aug 30, 2006 | 01:15 AM
4drjdm's Avatar
4drjdm
have you figured the d4 problem out yet cause mine does it too?
Old Sep 1, 2006 | 06:34 PM
SirHybrid's Avatar
SirHybrid
I know in a 5G when this happens, it's time to kiss your SS tranny goodbye. But then again, people say that the SS isn't a reliable transmission. I disagree, but that's what they say.....
If I had to venture a guess, it may be your neutral safety switch. If the car isn't in park or neutral, it will not start. Try starting it in neutral.
Old Sep 2, 2006 | 06:03 PM
Lynxx's Avatar
Lynxx
Methanol Drinker
When D4 flashes on your dash, it means that there is either;
a) a communication error between the ECM and the TCM (Transmission Control Module) OR
b) A problem with one or more TCM controlled devices.
This could be a result of many things. In the case of the engine not wanting to start, it could very well be the P/N safety switch causing the problem. Both the ECM and the TCM take signals from all the engine sensors (TPS, IAC, CTS, O2, etc) so a good place to start with this issue is to see if there are any current or stored codes in your ECM and correct them as needed.
Generally, the D4 light will flash if your TCC (Torque Converter Solenoid) or Shift Solenoids are having problems. The P/N Safety switch is another that will cause this.
One last thing could be at fault here... and I hate to even mention it. The TCN or ECU could be having problems (faulty).
Hope this helps.
Old Sep 9, 2006 | 08:06 AM
Davey2Crazy's Avatar
Davey2Crazy
Heyyy guys I just happended 2 be on the boards today havent been here for a few months. And I used 2 have the same problem. 1st to see if this is the same problem, my car wud neva start if sitting directly in the sun. But if it was in the sahde or no sun out it wud start fine. And the car wud never start if the light was blinking. U need 2 change the main relay. It's within the wiring behind the dash like where u would keep ur alarm brain. The piece is not expensive @ all and u can put it on ur self unless u wanna pay honda there 80$ a hour. Hopefully I helped some of u guys out, cuz I kno the annoying feeling of wondering if u could leave in time....
Old Sep 9, 2006 | 10:03 PM
PoloBoy's Avatar
PoloBoy
I agree with the guy above me, main relay is most likely the cause, I don't have an automatic but I know that whole "my car will start sometimes, and sometimes it won't" so then you sit there maybe smoke a cig or something and then try it again and???huh!?!? it started, yeah this really will happen a lot if its really hot outside or if you drove the car for a little while and then stopped and maybe ten mins later you go to try to start it and nope not happening. I would have that checked that is my guess on you guys problem, not to mention its a hell of a lot cheaper than all those tranny parts and it can be tested so do yourself a favor the next time you get it started go to the dealership and say heres my key, I think my main relay is going out and explain to them exactly what your car is doing. goodluck
Old Sep 10, 2006 | 05:56 AM
VPUPPY's Avatar
VPUPPY
If it was the main relay, the D4 light would not blink. You have an issue with the transmission.
Old Sep 18, 2006 | 08:43 AM
Davey2Crazy
Alrite guy, is it the main relay and it does make the D4 light blink cuz that's exzactly what mine did. So don't tell me it doesnt, Thanks...
Old Sep 18, 2006 | 09:36 AM
VPUPPY's Avatar
VPUPPY
Do me a favor, find me one document (shop manual, etc) that stays the D4 light blinks when there is a problem with the main relay. The TCU handles the trouble codes for the transmission and it blinks the D4 light for transmission related issues.
Old Sep 18, 2006 | 10:15 AM
Davey2Crazy
Well I don't care what any manual says, because I had my entire transmisson checked out and it was fine. So what does that tell u..And if it were the transmission I doubt it would function differently depending on the sun. I Don't mean 2 argue, but I'm for sure thatthe main relay is the problem for this..
