E-brake Adjustment
Old May 27, 2006 | 07:14 PM
scscase14's Avatar
scscase14
Default E-brake Adjustment
can you guys tell me how to adjust my e-brake. when i pull it, it doesnt slow me down as fast as it should. can you tell me were i need to look to adjust it and how. it is a 1998 manual.
Old May 27, 2006 | 07:56 PM
hattrick58's Avatar
hattrick58
Why are you using your parking brake to slow you down?
Old May 27, 2006 | 11:38 PM
scscase14's Avatar
scscase14
i first noticed something was right when i parked on a hill and set my e-brake and it slid on me, so i put it in gear. the next day i went in a parking lot and tried it out and pulled it up and it was like there was no change at all.
Old May 28, 2006 | 06:10 AM
hattrick58's Avatar
hattrick58
It's a pretty straightforward adjustment. You should check your pad thickness first and change them out if they're worn beyond limits. If you can't read the Word document (sometimes going from PDF to Word doesn't work so well), you can download the shop manual @ http://www.hondahookup.com/
Good luck.
File Type: doc
