Weird brake lights issues with 93 H22
Old May 23, 2006 | 01:44 PM
ne0277's Avatar
ne0277
Default Weird brake lights issues with 93 H22
Okay, done a search but nothing seems to be out there.
The problem is I get the "brake lamp" light on my dash but all the lights are good (checked them twice). And occasionally when I have the either blinker on and use the brake at the same time the lights go haywire. The brake lights would flash along with the third brake light and all other lights. I've checked all the connections but cannot figure it out. It is an intermitten problem.
They also go crazy if I have the headlights on and use the brake. The rear would all light up and the front signals would light up as well. They light up and a lower intensity. I'm going crazy over this issue. What could it be???
Any help would be appreciated or if anyone is having the same problem please enlighten me as to what I shoud do.
Thanks
Old May 24, 2006 | 06:50 AM
ne0277's Avatar
ne0277
never mind. figured it out. bad ground wire in the trunk...
