battery question
Old Apr 20, 2006 | 02:48 PM
edulerp87's Avatar
edulerp87
Smokin Lude
From: wappingers falls ny home of the gangsta rednecks
Default battery question
a while back my 99 5th gen had a prob starting...just clicking and then id hold the key down and it would click click then start to turn over. turned out there was just acid and corrosion on the terminals cleaned em up and it worked fine..that was 3 months ago now theres 2 x as much corrosion and its doing it again...whats causing the build up on my battery..is it the battery or is it something worse/else
thanks
Old Apr 20, 2006 | 05:15 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
You can get some kind of gel at Autozone, Pepboys or whatever that stops the corrosion.
Old Apr 21, 2006 | 12:43 AM
jumpman83's Avatar
jumpman83
^Word. If for some reason that's not good enough, then your luck pretty much sucks, but other things to consider would be: you live in a town named after some falls? Freshwater or saltwater, and how close? That could (doubtfully, but possibly) be part of it. Could also look into getting a maintainance free battery. Less likely to leak or corrode. (optima batteries = kick ass)
Old Apr 21, 2006 | 06:27 AM
edulerp87's Avatar
edulerp87
Smokin Lude
Default thatnks
yea..i had used petroleum jelly and past cars and never had a problem..i totally forgot about that though.. lol...i assume the gel is very simular...thanks for the help though..im gonna just buy a new battery soon n e way and i was already thinkin optima
thanks alot... oh and wappingers falls is freshwater and im far from them...just south of poughkeepsie NY if u know where that is
Old Apr 21, 2006 | 03:36 PM
asheylarry's Avatar
asheylarry
the corrosion is caused by leaking battery acid. if you just replaced your cables and not the battery then you will end up with the same problem every time. if the new cables are correded you need to replace them asap. corrosion is like cancer and it will work its way to the power distribution box and fuck all that shit up, then your really going to be in trouble
